RCU Forums - View Single Post - Using Hitec S with Futaba J
Old 12-06-2006 | 12:46 PM
bruce88123
Default RE: Using Hitec S with Futaba J
You'll find that to use the Futaba servos with the Hitec RX you will probably need to remove (file/cut) the index tab from the outside of the plug. After this just be careful not to install the plugs backward. No damage will occur but they will not run and it may confuse you briefly. Also only use the correct screws to hold the output arms in place. Using the wrong arms may damage internal parts.[:@]
