RCU Forums - View Single Post - Super Skybolt Build
Old 12-07-2006 | 08:12 PM
ChrisMH's Avatar
ChrisMH
Default RE: Super Skybolt Build
Made some progress this evening.
I build slowly, by the way...I say it's because I'm meticulous. My wife has another word for it...but whatever
1. Got a package in the mail today. I've never used Koverall before; should be interesting. I think I'll buy an airbrush when I get to the finishing stage.
2-3. This is a jig I made to cut clearances for the Robart hinge points. It allows me to cut uniformly for all hinges. I use the jig on the LE of the control surface to mark the location of the cutout. Then I use a square to extend that location to the left and right sides of the control surface. Then I align the jig with the marks and cut along the edges. Some cleanup on the inside and you end up with:
4-5. A nice clean clearance. And they'll all be the same, which appeases my need for uniformity.
6. Sanding block I made to bevel control surfaces.
7. The sanding block makes it easy and quick to make a nice clean bevel on both sides.
8-9. The results. A nice tight hinge joint with plenty of travel. Pretty happy with this one. Now...to repeat it 6 more times.
10. I'm sanding the elevators as a unit to ensure they're symmetrical.
11-12. Now that the elevators are symmetrical, I can trim the ends of the stabilizer to match the elevator balance tabs. Can't get much better than that
Hmmm...do I take too many picutures?
TBC...
ID:	573458   Click image for larger version
ID:	573459   Click image for larger version
ID:	573460   Click image for larger version
ID:	573461   Click image for larger version
ID:	573462   Click image for larger version
ID:	573463   Click image for larger version
ID:	573464   Click image for larger version
ID:	573466   Click image for larger version
ID:	573467   Click image for larger version
ID:	573468   Click image for larger version
