RE: Second plane.
The Tiger is a fine plane. On a lot of the Tiger ARF kits the hole is in the wrong spot for the throttle cable and also for the steering arm if you want to build it as trike gear. Not a big deal, just seal the holes wih some 5 minute epoxy and drill new holes. I would make it as a tail dragger and use a Sullivan tail wheel assembly myself. The Os 65 will pull the plane around pretty good. Personally I would have bought a TH 75. For me the engine is tops in the size range. ITs a much stronger running engine, very easy to adjust and, it also just happens to be $15.00 cheaper than the OS 65. [8D]
