Second plane.
Graham: You will definitely like the Tiger 60. I still have mine and it still flys great. The only issue I had (still have) with mine is the nose wheel assembly. I am going to convert the Tiger to tail dragger mainly because of this darned nose gear. Other than that, it's a great plane and you will get a lot of flying time with it. Your choice of engines will do just fine too. Good combination. Best of luck with it.
DS.
DS.
The Tiger is a fine plane. On a lot of the Tiger ARF kits the hole is in the wrong spot for the throttle cable and also for the steering arm if you want to build it as trike gear. Not a big deal, just seal the holes wih some 5 minute epoxy and drill new holes. I would make it as a tail dragger and use a Sullivan tail wheel assembly myself. The Os 65 will pull the plane around pretty good. Personally I would have bought a TH 75. For me the engine is tops in the size range. ITs a much stronger running engine, very easy to adjust and, it also just happens to be $15.00 cheaper than the OS 65. [8D]
what in the heck did you guys put in the kaos to get it to go fast? my dad has one w/ a 46ax and while it is a nice plane to fly, it is anything but fast. russm
