Try using some model rocket body tubes and premade balsa or plastic nose cones and glass them, it will save a lot of work. If the diameter is larger than 1.5" or so, you could even get some phenolic or composite tubes for additional rigidity.
Some sources to check:
http://www.balsamachining.com/
http://www.semroc.com/Store/Products/NoseCones.asp
http://www.apogeerockets.com/building_supplies.asp
Good luck!
Barry
