RE: F27 STRYKER - Way Past the Limits - Part 5 - Step in to the Dark Side...
While checking my Stryker over for its maiden flight, I noticed what appeared as fixed incidence trim-tabs, at the trailing edge of the wing, and perpendicular to the tail fins. The tabs are on both sides of the tail fins, at the rear.
Sighting down the nose, you may see the incidence of these tabs, with a bit of "up" incidence built-in. They are part of the wing foam structure.
Anyone care to comment?[8D]
