Cap 232 rudder problem
I just got the 85" cap 232 from wild hare.
everything has worked out pretty well aside from a few hinge holes that were drilled slightly off. The sheeting had a couple spots on the wing where it had been crushed. Just had to cut the covering back to reglue those.
the problem im running into now is that on my rudder pull pull system I cant get more than 25 degrees throw out of the rudder. The reason is that the pieces that come off the control stud hit the fuselage at 25 degrees. they arms have been trimmed to be in line with the hinge line and the control stud has been left at full length.
I cant seen any other option to get more throw out of this.
anyone else have this problem?
