ORIGINAL: sparky925
OK all, i am doing a little research for myself for my next 2 meter ship to be electric.
Please post your setups: motor, polys, speed controllers
Also add your preferred and tested props with rpm and current.
Thanks in advance.
Plettenberg 30-10 Evo, Schulze 32.80KA, TP 10s 5300's. - Either an APC 21x13W or 20x15 - RPM static - 6350-6400 - Amps 75 - both props are very similar in rpm/load, 20x15 has more speed and power.
Same setup with the new 5000 Extremes - 6500-6600 RPM static - 80A
Either setup in flight is around 70-75A max usually, dont know the in flight rpm.
