RCU Forums - View Single Post - GP Cap 232
Thread: GP Cap 232
Old 12-11-2006 | 03:04 PM
  #305
Al Lewis
Banned
Default RE: GP Cap 232
I put my EI unit on the left outside of the engine box and wrapped it in 3" aluminum foil ducting tape for further shielding. Don't have any problems with RF interference but it sounds like you may be getting outside interference. Pretty hard to control that without PCM. Ask your club members if they have tried any other fixes for the outside RF they are experiencing and make sure you program a failsafe to cut your engine if you do get a hit. Be careful with that polyurethane glue, it foams up quite a bit.
ORIGINAL: ricomari
Thanks guys! I'll stick to my FM for now. I'm in the process of gluing the point hinges to the ailerons using Gorilla Glue. I've never used the stuff, not sure if I'm putting enough. I did oil the center of the hinges and all seem to be going good so far. I'll wait till the morning to do the pull test.
