RCU Forums - View Single Post - AK-Models GOOD? BAD? UGLY?
Old 12-13-2006 | 12:02 AM
  #63
AK Models
Default RE: AK-Models GOOD? BAD? UGLY?
Could you forward e-mails you sent?
We could not have not answered to e-mail about defects...
I also looked-up records to find your name, no Shanes purchased Spitfire from us, unless you used different name or different company to buy it from.
Let me know i will double check.
ORIGINAL: Pit-Viper 1
I purchased the CMP spitfire 90 from you at the begining of the summer and got it promptly. All hardware looked good upon intial inspection, no crushed panels or tears in covering. However, once I started to put it together I noticed Imediately the all but one control surface was warped, I called and emailed with no response. So I decided to build anyway, then I noticed that one wingtip from the outer edge of the aileron to the leading edge was 1/4" shorter than the other. Once again , email, call, no response. So in the attempt to try and fix this myself and getting very leary about flying it , this is how it looks today. Trying to decide if its worth glassing and trying to even out all the warps and the shortened wingtip or just leave it as a reminder.
Shane
