RCU Forums - View Single Post - mt2 high idle problem
Old 12-14-2006 | 11:01 AM
---RC PiNYoT---
Default RE: mt2 high idle problem
Sounds like both the slipper clutch and maybe the low speed needle needs to be adjusted. Check pg 11 of your manual to adjust the clutch and then reset your lsn to factory specs (page 10) to rule out a lean lsn setting.
