mt2 high idle problem
NY
Just started the car. its run for about 3 minutes total. The problem is that when I start it it seems to idle pretty low but when I lift it off the ground the tires start spinning like crazy. could it be the slipper clutch? thanks for all your help
Sounds like both the slipper clutch and maybe the low speed needle needs to be adjusted. Check pg 11 of your manual to adjust the clutch and then reset your lsn to factory specs (page 10) to rule out a lean lsn setting.
GA
If the truck is not trying to move when on the ground then I would think the clutch is OK and the slipper should not have anything to do with your problem. As far as idling try to idle it up and many be need to adjust the LSN.
