RCU Forums - View Single Post - automatic extinguishing device for jets
Old 12-14-2006 | 11:55 AM
digitech
My Feedback: (10)
Default RE: automatic extinguishing device for jets
ORIGINAL: BirdofpraY
Only one huge problem, what if there is a impact that scatters the plane, and the device is from the hot point. Almost always when there is a impact that usually slings things get spread out from the impact zone. BVM was working on a retarder pack for the early bobcats where on impact it would explode all over the place to kill a potential fire but that ended up not going anywhere, due to the substance he was using, was to corrosive to the turbine.
most fires i have ever seen where actualy user errors and occur on starting.
now if you could save yours for less then 100 usd , this a would be a good item right?
and mostly if the parts are so scattered over the place then i dont think it actualy matters anymore , everything is lost anyway..
my goal is to this great invention called Kerostart......
we will see some guys running....
