RCU Forums - View Single Post - Securing struts to plastic floats -Thanks Everyone!
Old 12-15-2006 | 07:25 PM
JimCasey's Avatar
JimCasey
Default RE: Securing struts to plastic floats
Plastic floats are not really considered an emerging technology. Are you sure that those did not come with ply or hardwood reinfocements INSIDE? The Falcon Trading/ModelFly/Hobby People floats have a wood spine inside the raised flat area on top of the float for just that reason.
Hold 'em up to a bright light. Stick a wire down the screw hole. DO whatever it takes to be sure that there is not already an inside reinforcement part. If not, PFM/ShoeGoo makes a pretty good adhesive for sticking ply to a slick surface. Put a glob on, slap on the ply plate, and tape it securely in place. Check it tomorrow and it will be >>Attached<<<.
