RCU Forums - View Single Post - need help!!!!!!
Old 12-16-2006 | 11:20 AM
ssj2's Avatar
ssj2
Default RE: need help!!!!!!
From going to IHobby, there's a pull start equipped with the Rascal stock. Unless you removed the pull start, which wouldn't be a good idea, then you would stick the glow igniter in the engine, prime it (by plugging the exhaust and then pulling the pull start until fuel goes into the carb), and then use the pull start to start the truck. If your truck's tuned correctly, then it should start up pretty quick. Just make sure you don't over-prime/flood the engine when priming it. I couldn't really pinpoint what you wanna know because you weren't really detailed in the problem, but hopefully this helps! [sm=confused.gif]
