RC Nitro Stadium Trucks Discuss all aspects of rc nitro stadium trucks here
need help!!!!!!
Old 12-16-2006 | 11:11 AM
bmx833's Avatar
Default need help!!!!!!
i need to no how to start a schumacher rascal
Old 12-16-2006 | 11:20 AM
ssj2's Avatar
Default RE: need help!!!!!!
From going to IHobby, there's a pull start equipped with the Rascal stock. Unless you removed the pull start, which wouldn't be a good idea, then you would stick the glow igniter in the engine, prime it (by plugging the exhaust and then pulling the pull start until fuel goes into the carb), and then use the pull start to start the truck. If your truck's tuned correctly, then it should start up pretty quick. Just make sure you don't over-prime/flood the engine when priming it. I couldn't really pinpoint what you wanna know because you weren't really detailed in the problem, but hopefully this helps! [sm=confused.gif]
Old 12-16-2006 | 04:48 PM
No, you would keep the igniter out of the engine when priming, then when ready to start the engine, you would put it in.
sorry for the confusion
Old 12-16-2006 | 07:05 PM
ssj2's Avatar
I knew I was forgetting something, thanks for the reminder. I do this so much I begin to forget, terrible...
Old 12-18-2006 | 02:49 AM
bmx833's Avatar
i got the pullstart in.
so wat ur sayin is that you put the glow starter in while covering the egsaust then pul the pullstart
Old 12-18-2006 | 02:53 AM
bmx833's Avatar
or do ya just put the glow starter in and pul the pullstart
Old 12-18-2006 | 03:13 PM
Cover the exhuast with your finger then pull on the pull start. Not hard, just enough to pull it out (your not trying to start the truck/car..just move fuel). Watch the fuel line coming from the tank to the carb. You should see fuel heading towards the carb. Once youve pulled it enough to get fuel all the way threw the line and into the carb(dont get to much fuel in the carb or it will flood it..just get the fuel right at the carb), then place your glow ignitor on the plug and proceed to try and start. Of course remove your finger from the exhaust when trying to start it.
