RCU Forums - View Single Post - Easy Question
Old 12-16-2006 | 05:14 PM
Flak
Default RE: Easy Question
Baja236,
Easy Answer: Pull the rubber stopper out of the electric starter. Turn the stopper around and put it back in the starter. Place the small hole firmly against the prop nut and press the starter button. Walla, your engine will start. I just saved you thirty bucks. Pass it on and save someone else some paydirt down the road. Good Luck and Happy Landings.
