RCU Forums - View Single Post - Easy Question
Old 12-16-2006 | 06:41 PM
Flak
Default RE: Easy Question
Baja236,
Rotate the prop clockwise until it is about to bump, place the reversed rubber cone plug on the prop nut, make sure the starter is properly in line with the engine and engage the starter. This should get her turning over. Make sure the cylinder head is not loading up on you.
