ORIGINAL: mouthpiec
Hi all,
I use the Futaba 6YG Tx and the R147F Rx.
Is there any replacement for the Rx that might improve performance?
thanks and regards
sandro
Since you are not US based it is best to point out that you are from Malta and are flying on something other than 72 MHz. The majority of people on this board are from North America and will assume you are on 72 MHz.
I have a Futaba 9C and use almost all Hitec receivers, but I don't know if Hitec has receivers in your band. I read above that they do not.
Also the issue of positive and negative shift may not be an issue in your country.
We welcome your posts, but for your own benefit, name your location when you post.
