RCU Forums - View Single Post - What radios will work with split servo elevator?
Old 12-17-2006 | 01:58 AM
Rod Bender's Avatar
Rod Bender
Default RE: What radios will work with split servo elevator?
I ran into this problem while setting up my Funtana 90. An option is to use a Y harness, and run 1 Futaba servo, and 1 Hitec servo. The Hitec servo rotates in the opposite direction as the Futaba, and the Hitec is compatible with your Futaba rx. Just another option .... Greg
