RCU Forums - View Single Post - Mini Delta 2000 - almost complete
Old 12-18-2006 | 02:12 AM
izzy
Default RE: Mini Delta 2000 - almost complete
DOWN BOYS DOWN
i am not sure about a video, but i will try and get one for the day of the test flight
regarding engine - it is a tuned engine by Dub for high rev Jett 50 - he sent me the props as well as tuned the engine - rpm close to 22000 from what i remember , but will let you know
i am using a cut down 8.8 x 9.0 apc prop
obviously it has vertical fins - i wrote in the original posts that i have to cover them still
regarding the cg, it looks like it is pretty close on, the battery is right at the back of the wing , and the servos ( hard to see, are set inside the wings )
the feul tank is on the CG , and i was advised i might need a perry pump to get the flow from the wing to the carb
the only thing i am now trying to find a solution for ( without breaking the nice curves ) is a place to fit the remote needle valve - i am open for suggestions
