ORIGINAL: mikenlapaz
From other threads I believe reducing the case volume is a benefit. Not sure just why; maybe someone can explain for us only semi mechanical hobbists.
Reduced crankcase volume leads to improved primary compression, increasing the ability of the engine to generate power and to feed the combustion chamber at higher RPMs.
