RCU Forums - View Single Post - Zenoah 25.6cc builder kit
Old 12-18-2006 | 03:13 PM
  #36
mikenlapaz
Default RE: Zenoah 25.6cc builder kit
Tight for tapping in with a plastic mallet...Too tight will crack the casting...Plastic mallet tight with Loctite is good, the pressure in the case is only 5 or 6 lbs and not constant...
Same install procedure for the bearings; Tap in with Locktite?
