RE: Input Please
Either of these 2 kits will run you over $1000 when done...if you try to cut corners then you'll only run into hard times and end up costing you more and more money later on...that said you cant go wrong with either truck...one is not better then the other...both are at the best of the best in the game...and it all comes down to driver skills.
