RCU Forums - View Single Post - GP Super Skybolt progress
Old 12-18-2006 | 11:40 PM
parrthd
Default RE: GP Super Skybolt progress
just a quick update on mine.......
found the problem with my "limited" vertical........bad rear crankshaft bearing. took it out a couple weeks ago and the motor sounded like ....... i don't know what. shut it down and turned the prop, there was a scrub and grind in it.
brought it home and found the cage that keeps the balls spaced out was completely gone. nothing but small pieces (app 1/8 by 1/4 or less) left. got new bearings from a bearing supply house locally and ....... WOW talk about a difference.... it flies lilke a different plane. i now have enough to go as high as i dare. the 1.20 does this plane wonders.
