landing problem?
When you are making your base leg to final point the nose of the plane right at you and it will almost always put you over the centerline at touchdown, of course it will not always work due to drift from crosswinds and such, you will eventually learn to overcome that as well but as den1tjb it will boil down to practice,practice and more practice. Stick with it, you will get it!
Chris
