RE: Counter-rotating nitro engines,,,
If the engine has a removeable front housing, like some of the older Super Tigers, you can rotate the front housing 90 degrees in the direction the engine currently rotates and the engine will run backwards. Same concept with a rear induction engine. Otherwise a reverse rotation crankshaft is required.
