RCU Forums - View Single Post - Opensource CDI ignition
Old 12-21-2006 | 10:50 PM
  #155
RysiuM's Avatar
RysiuM
Default RE: Opensource CDI ignition
ORIGINAL: acgeorge
BCMA has them for $85 w/auto advance.
Reading instruction I found funny thing (maybe it is not quite funny, but plain wrong).
...If you run electronic ignition Radio Interference is always a possibility. If you encounter this problem here are some ways to help reduce or eliminate this problem....
If you are still experiencing problems, here are some more extreme measures:
· Wrap your ignition module with Aluminum Foil.
· If your ignition module is mounted on your firewall, apply HVAC foil ducting tape to the firewall.
· If your ignition module is inside a compartment, line the compartment with either Aluminum foil or HVAC foil ducting tape.
· Upgrade to a PCM type radio system.
The last "extreme" is a real hardcore. The most stupid thing would be masking interference by using PCM. [:'(]
