RCU Forums - View Single Post - CMP Hellcat
Thread: CMP Hellcat
Old 12-22-2006 | 12:43 PM
  #1383
hookemut
Default RE: CMP Hellcat
ORIGINAL: ffdq
Hi my cat climes with almost no control,also the ele.has alot of play.I had 5 flights with no problems then it started.Is this flutter.
thanks
Hi,
It is quite likely that whatever causes flutter is visiting your model now, and that flutter itself could take place. Keep your airspeed down, check for slack in the model's elevator servo, pushrods, horns, etc. Did you 'Y' your elevator pushrods? If so, you may be getting flexing at the 'Y'. The model gods have given you a warning-find the problem(s) with your elevator system!! Good Luck!!
hookemut
