RE: Rudder wont work
Its a ARF plane and the instructions say were to put it. The rudder has like paper strips in between the rudder and the tail plane so that the rudder can move but when you try turn the rudder right the rudder gets pushed out where its coneccted with the strips to the tail plane. But when the push rod is pulled it turns the rudder fine to the left.
Thanks a lot
Matthew
