 Rudder wont work >
Rudder wont work
Rudder wont work
Old 12-22-2006 | 01:35 PM
Default Rudder wont work
Hi Guys,
Ive got a piper cub and need help because the push rod doesnt work properly. The push rod pulls the rudder left but instead of pushing the rudder right the rudder comes out(gets pulled out the tail plane) Does anyone know what I need to do to make the rudder turn right not be pulled out the tail plane?
Thanks a lot
Matthew
Old 12-22-2006 | 01:39 PM
Default RE: Rudder wont work
Are the hinges installed but not glued yet? Of course you don't want to glue them until after covering. And are the hinges exactly in the centerline and exactly parallel?
Old 12-22-2006 | 01:47 PM
Its a ARF plane and the instructions say were to put it. The rudder has like paper strips in between the rudder and the tail plane so that the rudder can move but when you try turn the rudder right the rudder gets pushed out where its coneccted with the strips to the tail plane. But when the push rod is pulled it turns the rudder fine to the left.
Thanks a lot
Matthew
Old 12-22-2006 | 01:56 PM
RCKen's Avatar
RCU Forum Manager/Admin
My Feedback: (9)
Your problem here is that the hinges haven't been properly installed. Those "paper strips" are called CA hinges. They are designed to be glued to the structure using thin CA adhesive. RCU member Minnflyer has done an excellent "how-to" on installing CA hinges. You can find there in the RCU Magazine here: [link]http://www.rcuniverse.com/magazine/article_display.cfm?article_id=55[/link]
Hope this helps
Ken
Old 12-22-2006 | 03:15 PM
Matthew,
You might want to tug on your elevators and ailerons to see if those hinges have been glued or not too.
Dan
Old 12-22-2006 | 04:30 PM
RichD's Avatar
best to catch that now, or you would have some serious flutter
Old 12-22-2006 | 07:01 PM
horace315's Avatar
My Feedback: (15)
a lot of arf's come with the control hinges not installed and sometimes slots for the ca hinges not put in,unless they say pre-glued they usually aren't and i always check my hinges regardless,the reason the rudder comes out is because r/rudder is pushing l/rudder is pulling and there doesn't appear to be any glue or like ken said not glued properly.
Old 12-23-2006 | 11:32 AM
Thanks a lot guys that was the problem. Off to glue the ca hinges. Will be in the air soon.
Thanks a lot again.
Matthew
Old 12-23-2006 | 01:23 PM
exeter_acres's Avatar
is this your first plane?? I don't recommend a J3 Cub as a first plane......
They may "look" like trainers, but they do not fly like trainers
Old 12-23-2006 | 11:47 PM
ORIGINAL: RCKen
Hope this helps
Ken
Man, that guy Ken is always on the case!
Seriously, I can almost predict based on subject lines when a post from you will appear, almost as if by magic. My hat is off to you for your generous contribution of time and knowledge on these forums. Thanks on behalf of all of us who have benefited from your experience.
Erik
Old 12-24-2006 | 02:50 AM
Yes its my first plane. Ive been told all about how its not a train and needs a lot of rudder work.
Matthew
Old 12-24-2006 | 09:39 AM
I've watched my father (who has been flying for over 20 years [at-the-time, since then quick the club]) crash a J3 Cub and other such planes, and he was a certified member of the air club - a PROFESSIONAL.
With my father being a professional and crashing these types of planes, there is no way a beginner can fly them . . . . . I strongly suggest you do not get one as a first plane . . . . and get a TRAINER
Just my opinion!!!!
