RCU Forums - View Single Post - TT .46 install
Thread: TT .46 install
Old 01-28-2003 | 04:41 PM
Matt Kirsch's Avatar
Matt Kirsch
My Feedback: (21)
Default TT .46 install
You should adjust the carburetor so the engine will idle with the throttle stick all the way down. Then, when you press the kill switch, the carburetor should close fully. Use your throttle trim to adjust the idle when the engine is running.
Why do you feel you have to rotate the carburetor to get the adjustment? Adjusting the length of the pushrod should achieve the same purpose.
