RCU Forums - View Single Post - E- Miss LLumar
Old 12-22-2006 | 11:24 PM
TrunkMunky's Avatar
TrunkMunky
Default RE: E- Miss LLumar
I doubt the hull weighs a pound,anyways ,I gutted it without a problem,except for the servo,which was glued to the hull and not mounted correctly,there was a mount glassed into the hull that wasn't being used properly,so I had to rip out the other servo with pliers and dremel out all that glue and use the mounts correctly.here is a comparo pic of the batteries,the top one is the one that fits,2 should work nicely.
ID:	582135   Click image for larger version
ID:	582136   Click image for larger version
