weight verse performance and durability
want your opinions . is it generally true that a heavier plane will have lower performance than the same plane and set up that
is heavier. at what point does the aircraft suffer in durability being lighter. also the heavier the aircraft the hotter it will have to
land and more fuel will be used to maintain same performance. what do you think?
