RCU Forums - View Single Post - Clear dope substitute?
Old 12-24-2006 | 03:56 PM
Phlip's Avatar
Phlip
Default RE: Clear dope substitute?
If you want to attach tissue covering, you can use a glue stick or thinned white glue (Elmers). Tissue can be shrunk with a light mist of water after the glue has dried, and the tissue can be painted with regular spray paint or left natural color and sealed with a clear spray such as Krylon. This'll be OK as long as your not using a glow powered engine, as none of this is fuel proof. If you're going wet power, you'll need the dope, or use iron-on plastic covering.
Hope this helps,
Phil
