RCU Forums - View Single Post - BEGINNER'S BUILD - Tower Trainer .40
Old 12-24-2006 | 09:07 PM
  #51
shd3920
Default RE: BEGINNER'S BUILD - Tower Trainer .40
Ken and bruce - - - you are making sense, and apparently I would be a fool for going against your advice [sm=bananahead.gif], if anyone would know what they are talking about it would be you and bruce - - - so, I am going to follow your advice and glue blindnuts into the holes I drilled for the screws and do it the proper way . Thank you for sharing your thoughts and advice. Will post pics soon with the corrections.
ORIGINAL: RCKen
ORIGINAL: tigerdude426
Sorry if I am wrong with this opinion, but I still say the screws are stronger.
I'm going to disagree with you here Tigerdude. First of all, if you put a small dab of epoxy on the back of the blindnut it will not fall out of the backside of the firewall. To say that screws are stronger isn't looking at the whole system. With a screw you have a just the threads to transfer the power of the engine to the fuselage. But with a blind nut you have a larger surface area with the back of the blind in contact with the firewall to transfer that power to the fuselage. And lastly the threads that you have cut in the wood are nowhere near as strong as havign the metal threads of a blindnut. On a smaller engine like you are using on this plane it might not make too much of a difference, but when you get to bigger engines it's a bad practice as they can pull the threads out of the wood without even trying.
Ken
