RE: Seamaster .40 with an O.S. .55 AX
Hmmm. How many and what do they look like. I dont remember having any spare parts. If you are not using the land conversion, i.e. wheel and steerable front, you will have some hardware parts. Mine was dedicated for water use only and did not want to add extra weight.
WARNING. WARNING.
Before you drill the holes in the main wing for mounting the trailing edge, make sure it is over the blind nuts mounting in the fuse. Some booklets give measurments that will cause you to drill right through the aileron rods.
