Got it on the aileron servo tray.
1. Bought a Hobbico CS 35 mini servo which was reccomended by someone. It fits perfectly in the plywood tray. I peeled back a little covering from around the rectangular servo tray hole in the wing so I can epoxy the plywood tray ON TOP OF the wing. I will then mount the servo into the plywood tray with the associated hardware/servo screws. It is aligned as per your instructions.
??? One thing that doesn't make sense is P.3/#3 Aileron Servo {Lower} of the instruction manual concerning the control arms {right side of p. 3}.
1. The little rings that go over the red control rods are the same size. How do I get them to fit?
2. I do not understand how the "straper" works in the illustration. It looks like you bend the control rod at a 90 degree angle and put it through the control horn but how does the "straper work?
http://www.theworldmodels.com/para/i...on/html/A009S/
