RCU Forums - View Single Post - Engine HELP!!
Old 12-25-2006 | 01:26 PM
jaka
Default RE: Engine HELP!!
Hi!
Fill the tank....Then blow trough the pressure line going to the tank....if fuel gets to the carb and trough the carb into the engine...the engine can't say no top starting (povided the glo plug is good, should be an OS F plug).
But ...if the engine has been sitting for as long as 5 years...and has been run on Castor oil..then you must probably change ball bearings.
