RE: Newbie with aproblem need help
Searching this and the MTG forums will provide you with all the information/pictures you need. For the Tiger you have to remove the tracks first by pushing a pin out of each side's link. then remove the forward 2 screws on either underside sponson and finally a screw on the bottom up front and two in the rear. Then carefully separate the two hulls, disconnecting the antenna wire and wiring harness to the upper hull/turret. You can test the tank with the upper hull off at short distances. Have Fun!
