RCU Forums - View Single Post - couple nitro evader st questions
Old 12-26-2006 | 08:03 PM
hifooy07
Default RE: couple nitro evader st questions
wow thanks for the great info. ill order the bx parts tonight. the problem with the starter, ill pull start it, drive it around a little then if it flips over or i shut it off, fuel gets into the pull start and covers the string and 1 way bearing with fuel i broke the string 4 times already cause the string got so weak from the fuel. i replaced the pull start and the 1 way bearing i just dont understand why or how the fuel is getting in there. is there some sort of seal that might have went bad? also i thought the rc10gt was the same car? so wouldnt the steel spur gear work for the evader? i thought i seen something about that and the rc10gt having a 2 speed tranny?
