RCU Forums - View Single Post - Head scratcher
Old 12-26-2006 | 09:34 PM
ah64's Avatar
ah64
Default RE: Head scratcher
ORIGINAL: WhiteWolf McBride
ah64:
By the way you say it, I assume you're going to attach track blocks to the outside of your 'chain' to make the track, right? In looking at pictures of the T-27, it seems to have that central single disk-sprocket, with dual guide horns on the inside surface. The only problem I see there is that with only one central attachment point, the track blocks will have a tendancy to rotate on that point. One way to solve that would be a strip thin fabric to either side of the main attachment point to prevent this.
If you could find a close batch in a separate-link tracked vehicle it migfht be easier, as most tracks have at least two connection points (usually either end) and often have central holes that could be used for the sprocket teeth.
Only other option I see is having matching links cast, and that is not a cheap option.
I guess it becomes a matter of how accurate you wish it to be vs how much you want to invest in its construction.
Yeah I noticed that as well, On the 2D drawings they seem to have a very narrow track as wide as the drive sprocket its self. This would control the rolling effect or twisting of the tracks I would persume. The original track with of the full scale tank was around 8 inches. That is very narrow considering some tanks had a 20-22 inch width of track and them some.
