RE: CMP Cessna 182 Building Thread-->the best scale Cessna 1.20 size ARF that is on the market!!!
with regards to the center wing panel, ___consider_____ leave the 2 nylon rings off the lower surface. they hit the cross member of the fuse
drill the holes for the pins a little large. put he nylon guides in the fuse and test fit. epoxy the guides in. then epoxy pins and insert the wing. tape the trailing edge in position. this should give you a perfect fit.
