RE: Inner shaft on cx2
You should be seeing two screws that screw into the aluminum collar that holds the inner shaft and gear in place. Remove those screws pull up gently but firmly on that inner shaft hub and she'll pull right out. Upon reinstall, make sure those screws fit tighly into the flat indentations at the bottom tip of the new inner shaft and that there is little, if not any, up/down movement of the shaft.
