RCU Forums - View Single Post - Idling problems for 2 stroke gasser
Old 12-29-2006 | 03:36 PM
pe reivers
Default RE: Idling problems for 2 stroke gasser
Don't aim for lowest rpm yet. The engine needs to run in until smooth. That takes a couple of gallons.
At 1/3rd throttle, open the idle needle until rpm markedly drops. That should be a good start to work your way down.
Remember, to run without exhaust system, the settings you need may be very different from a full rigged setup.
