RCU Forums - View Single Post - No steering control on BCX
Old 12-29-2006 | 10:33 PM
dkme
Default No steering control on BCX
Hi all-
I'm the third owner of my BCX. After a few crashes, it barely responds to inputs for forward and lateral movement. The swash plate separated, but I glued it back together correctly. The lower rotor still shifts normally and the swash plate is working fine now. I've straightened the fly bar, checked the servos for correct centering, and toyed with the pushrod and fly bar linkages.
The lower rotor does get up to speed until about half throttle and I'm wondering if the motor is shot. I've checked the gears and they look fine. Has anyone experienced similar lack of control? I've noticed that when the heli is low to the ground, it is more responsive, maybe because the lower rotor is more effective under the ground effect. Thanks for any help.
dkme
