RE: Best way to break in the engine
eek! you'd think they would have mounted the engine properly. Two of the screws mounting it to the firewall had come loose and one was almost half way out - it can not be tightened fully it just keeps turning so I assume its going to rattle loose again. The other one thats loose is right behind the needle valve so I cant even get to it!
Also while checked the spinner, both screws in the spinner are also not tightening fully and just keep turning, is this a problem?
