Hi;
Another Idea---I Did This When I Built My Battleship USS Missouri--
Step Down Your Stuffing Tube With A Small Length Of Brass Tubbing- -This Will Make
Perfect For A 1/8th Shaft--
Than You Can Use the Universal--Or Whatever--Just Buy 2 --1/8th Threaded Prop Shafts
And R-L- Props you Like--And Your In---
I Will Go This Way--Will Let You Know How I Make out With This--Should Be NO-
Problem------Reason I Have To Do This -Is I Already Have The Dumas Stuffing Boxes
Sealed In Place--They Are For The 3/16- Shaft-..--I Bought The 700 Engines From e-Bay--
Good Luck----
PS You Can Work Around The Oiler--
Hope This Is Right-LOL--What Do u Think??
