Go Back  RCU Forums > RC Boats > RC Scale Boating
 the unofficial home of the dumas dauntless >
RC Scale Boating Enjoy rc scale boating? Talk about it here.
Old 06-04-2020 | 12:13 PM
  #5276
Hello DF. Happy to hear from you. All is well here and presumably also with you.
RichieRich1 (03-27-2022)
Old 06-05-2020 | 05:16 PM
  #5277
kokaneezer's Avatar
Hi Guys.
Old 06-06-2020 | 01:06 AM
  #5278
Hydro Junkie's Avatar
Wow, almost the whole gang has popped up. Anyone heard from Rich404?
Old 06-06-2020 | 06:31 AM
  #5279
Rich's last log on was Nov 2018 when he commented on Darron16's boat. I remember that he moved and got a new job that took most of his time.
Bob
RichieRich1 (04-15-2022)
Old 03-27-2022 | 07:52 AM
  #5280
Default I’m back!!!
Hey captains, it’s been years & I’m finally back in. I’ve tried everything I could for a really long time to log in with my Rich404 account, and I couldn't get in.
So without any further delay I’m back using this new account.
-Rich.
Old 03-27-2022 | 08:06 AM
  #5281
Default Dauntless update
I am still working on my Dauntless. Like anything, I juggle family, work and other projects however I never stopped sailing her. She has given me so many years of great service and from time to time I jump right on in.
Over the past couple years I have been refitting some past work documented in these pages to be more serviceable while pushing forward with fresh ideas & details.
I’ll post more pics, videos & more on my Dauntless soon enough.
Cheers!
-R.
Old 03-27-2022 | 11:47 AM
  #5282
Welcome Back, Rich
Been wondering what happened to all of you guys. You all just seemed to disappear, glad to know it wasn't anything health related.
Old 03-29-2022 | 09:18 AM
  #5283
Originally Posted by Hydro Junkie
Welcome Back, Rich
All’s well on my end. A long time ago RCU was going through site changes which made it very difficult to post pics.. so I moved to a neighboring site that was and is pretty active. As time went on I tried to log in and it kept failing. Rather than start a new profile I just kept doing forgot password upon failure and I wouldn’t get any pw reset emails which was odd. So, I finally caved in the other day and started new.
R.
Old 04-14-2022 | 03:00 PM
  #5284
good job
  #5285
good job
Old 04-14-2022 | 03:01 PM
  #5286
good job..
Old 04-15-2022 | 08:09 AM
  #5287
Unhappy
Originally Posted by sultanxuae
good job..
Well, I'm not allowed to post any pics until I have 10 posts.
-R.
Old 04-15-2022 | 08:13 AM
  #5288
There's so many details emerging at this point.
Where do I even begin?
-R.
Old 04-15-2022 | 08:23 AM
  #5289
When I set out to build the interior in the beginning of this thread I didn't anticipate the upkeep of the lighting system. I built it "as-If" things like lightbulbs, etc, wouldn't burn out. What a BEAST it was to remove things like ceiling panels to update lights. For a long time the lights wouldn't even work. As a result, it pushed me to rethink and address the issue by thinking outside the box to solution the issue. I'm still working on it.
-Rich.
Old 04-15-2022 | 08:47 AM
  #5290
Water is another issue I have been tackling. I would return from a run with water sloshing around the hull. I knew that with the interior installed it would only make it more difficult to upkeep as time went on. As a result of that, I had to cut access panels into the forward section where there is a fixed floor. This allows me to check under the floorboards and address leaks as well as run wires as needed deep below deck.
The salon floor was also reset to fully removable. This area is where I had relocated the power distribution panel, port and starboard LIPOS. Ultimately, this is the heart of the electrical system aboard the boat. I found that keeping the electrical and LIPOS out of the motor room was important because the motors used to get hot in there.
I also did many changes to the plumbing for water cooling over the years. The cooling system had two purposes, one was to cool the motors and speed controls, and the other was pure aesthetics. I had set out to blow large volumes of water out of the wet exhaust ports to capture the full sized Dauntless. I did so many different things from automotive washer motors, cheap water pump motors and more before ditching all of it. Then I came up with a way to custom make (4) 1/4" wide brass tubes per propeller that forced water through the tubes, cool the motors, esc's and blow out the transom in force. It Worked!!
Astro Flight
I also realized with he original Harbor Master ESC's that they really didn't need to be water cooled because they designed perfectly for the motors. Well, as time went by, the shrink wrap on the speed controls gave way, electrical components in the ESC came into contact with a cooling plate and started a fire aboard. Thankfully there was enough aluminum in the motor room from keeping the fire from spreading. Both ESC's were replaced with new ones and interestingly the new Astro Flight ESC's come in protected cases. It makes me wonder if they caught flack for burning down a boat? I currently still have the cooling plates installed for now however I'll eventually bypass the cooling plate and send the cooling forward to the LIPO Holders where they will circle back and back out the transom. The reason for this is to finish up some aluminum LIPO holders that I designed and if one was to go rogue and ablaze, the water cooling tube will melt and potentially save the boat. Hopefully I'll never have to experience that but my Dauntless will always a test bed for new ideas.
-Rich.
Old 04-15-2022 | 09:28 AM
  #5291
Soon enough
I'll be able to post pics again!
-R.
Old 07-11-2022 | 08:48 AM
  #5292
Hi
I have a Dumas Dauntless , that was built and never completed , this was 40 years ago . I have in mind to complete it now being retired .
I have two Dumas 12 volt motors already installed , along with the drive shafts and two opposing props .
If someone would be so kind as to direct me to the proper size speed control ( BEC ) , in amps that I would need to purchase , and do I need to purchase 2 BEC,s . It will be running on 2 X 12 volt gel batteries
Thanks for looking in
Michel
Old 03-27-2026 | 03:25 PM
  #5293
foodstick's Avatar
This thread used to be a BOOMER, with so much action,, I used to add and talk on here a lot. I even worked on a friends Dauntless, one he had picked up started, and rough. I hope he gets his finished some day as he has done some nice detail work on it. I still can not believe the real boat was beached, broken up and destroyed, what a history it had.
