RE: Opensource CDI ignition
The flywheel is not only for the ignition, but it helps also the engine a littlebit with the rotation.
The crank only itn't enough to let spin the engine, he needs also the (rotation) weight of the flywheel.
The prop is taken over the (rotation) function of the flywheel.
